Table of contents
- Basic information
- Installation
- Configuration
- DS18B20 temperature sensor installation
- Data exchange / MQTT
- openHAB configuration
- Information about new versions and problems reporting
It’s possible to connect Sonoff switch with this firmware to every home automation system which works with devices operating with MQTT Protocol. OpenHAB is one of such.
Required
- Installed and configured MQTT binding in openHAB
In openHAB 1
- you can install it using following command
sudo apt-get install openhab-addon-binding-mqtt
In openHAB 2
- you can install it with PaperUI or
- add to /etc/openhab/services/addons.cfg configuration file entry „mqtt” at the end of configuration parameter:
- binding = mqtt
Configuration of MQTT Binding in OpenHAB
In openHAB 1
- Look in /etc/openhab/configuration/openhab.cfg configuration file section „MQTT Transport” and configure access to your MQTT Broker
Example:
mqtt:broker.url=tcp://localhost:1883 mqtt:broker.clientId=openHAB mqtt:broker.user=openhab mqtt:broker.pwd=password
In OpenHAB 2
- In /etc/openhab/configurations/addons/mqtt.cfg configuration file configure access to your MQTT Broker
Example:
broker.url=tcp://localhost:1883 broker.clientId=openHAB broker.user=openhab broker.pwd=password
Items
Assuming in Sonoff switch configuration you entered MQTT Topic as /sonoff/light/
In the file *.items enter:
Switch sonoff_light "Light" {mqtt=">[broker:/sonoff/light/cmd:command:ON:ON],>[broker:/sonoff/light/cmd:command:OFF:OFF]"}
If you installed DS18B20 sensor in your Sonoff switch add following as well
Number sonoff_temperature "Temperature [%.2f °C]" { mqtt="<[broker:/sonoff/light/temperature:state:default]"}
Sitemap
To *.sitemap configuration file enter
Switch item=sonoff_light
Text item=sonoff_temperatura
Additional information
If you going to control device connected to Sonoff switch manually by build-in button and it’s important for you that openHAB is aware about such events add following to your openHAB configuration:
To *.items configuration file
Switch sonoff_light_status {mqtt="<[broker:/sonoff/light/state:state:ON:ON],<[broker:/sonoff/light/state:state:OFF:OFF]"}
Add rule to your *.rules
rule "Manual switch change of sonoff_light" when Item sonoff_light_status changed then if (sonoff_light_status.state!=sonoff_light.state) { if (sonoff_light_status.state==ON) { sendCommand(sonoff_light,ON) } else { sendCommand(sonoff_light,OFF) } } end
