domoticz - brak int...
domoticz - brak interface
1 Wpisów
1 Użytkownicy
1,184 Wyświetleń
(@krasus)
Wpisów: 14
dziś wyłączyli prąd na tyle długo, że UPS nie wytrzymał i stało się, nie działa.
Po próbie logowania przez www wyświetla komunikat:
Spoiler
error
Exception stack trace:
at System.String.Substring (System.Int32 startIndex, System.Int32 length) [0x00023] in :0 at System.String.Substring (System.Int32 startIndex) [0x00008] in :0 at Mono.WebServer.MonoWorkerRequest.AssertFileAccessible () [0x0003b] in :0 at Mono.WebServer.MonoWorkerRequest.ProcessRequest () [0x0000b] in :0
Spoiler
service status
service domoticz status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated)
Active: active (running) since Thu 2020-07-23 20:26:49 CEST; 5min ago
Docs: man:systemd-sysv-generator(8)
Process: 21665 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
Tasks: 27 (limit: 4915)
CGroup: /system.slice/domoticz.service
└─21681 /home/pi/domoticz/domoticz -daemon -www 8084 -sslwww 8884 -log /tmp/domoticz.txt
Jul 23 20:26:49 tartar systemd[1]: Starting LSB: Home Automation System...
Jul 23 20:26:49 tartar domoticz.sh[21665]: 2020-07-23 20:26:49.778 Status: Domoticz V2020.2 (build 12230) (c)2012-2020 GizMoCuz
Jul 23 20:26:49 tartar domoticz.sh[21665]: 2020-07-23 20:26:49.778 Status: Build Hash: 72d6b26e3-modified, Date: 2020-07-19 07:50:32
Jul 23 20:26:49 tartar domoticz.sh[21665]: 2020-07-23 20:26:49.778 Status: Startup Path: /home/pi/domoticz/
Jul 23 20:26:49 tartar domoticz.sh[21665]: domoticz: Domoticz is starting up....
Jul 23 20:26:49 tartar domoticz[21674]: Domoticz is starting up....
Jul 23 20:26:49 tartar domoticz[21681]: Domoticz running...
Jul 23 20:26:49 tartar systemd[1]: Started LSB: Home Automation System.
Spoiler
localhost:8084
wget localhost:8084
--2020-07-23 20:57:04-- http://localhost:8084/
Resolving localhost (localhost)... 127.0.0.1, ::1
Connecting to localhost (localhost)|127.0.0.1|:8084... connected.
HTTP request sent, awaiting response... 400 Bad request
2020-07-23 20:57:04 ERROR 400: Bad request.
w pliku /tmp/domoticz.txt mam logi stany z czujników.
apt upgrade oraz update domoticza nie pomogło.
Co można zrobić żeby ożywić domoticza?
P.S. udało mi się dotrzeć do błędu:
2020-07-23 21:30:56.335 Error: WebServer(HTTP) startup failed on address 0.0.0.0 with port: 8084: bind: Address already in use
2020-07-23 21:30:56.335 Error: WebServer(HTTP) check if no other application is using port: 8084
2020-07-23 21:30:56.343 Error: No servers are configured. Hence mydomoticz will not be started either (if configured)
i dodatkowo:
dashticz domoticz error double check
ciekawe mono zajęło port domoticza. Wyłączone i działa. (po co mono?)
Dodane : 23/07/2020 7:17 pm
