Aktualizacja Zigbee...
Domoticz Aktualizacja Zigbee2mqtt
1 Wpisów
1 Użytkownicy
1,332 Wyświetleń
(@szmydu)
Wpisów: 72
[#5786]
czy spotkał się ktoś z taki błędem, lub wie jak się go pozbyć :
Installing dependencies...
npm WARN prepare removing existing node_modules/ before installation
npm ERR! Cannot read property 'ajv' of undefined
npm ERR! A complete log of this run can be found in:
npm ERR!     /home/pi/.npm/_logs/2024-01-05T10_32_25_087Z-debug.log
Pojawia się podczas aktualizacji Zigbee2mqtt. We wskazanym logu jest:
0 info it worked if it ends with ok
1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'ci' ]
2 info using npm@6.14.16
3 info using node@v12.22.12
4 verbose npm-session 3809411c38989eb8
5 info prepare initializing installer
6 verbose prepare starting workers
7 verbose prepare installation prefix: /opt/zigbee2mqtt
8 verbose prepare using package-lock.json
9 warn prepare removing existing node_modules/ before installation
10 verbose checkLock verifying package-lock data
11 verbose teardown shutting down workers.
12 info teardown Done in 0.001s
13 verbose stack TypeError: Cannot read property 'ajv' of undefined
13 verbose stack     at /usr/lib/node_modules/npm/node_modules/lock-verify/index.js:27:40
13 verbose stack     at Array.forEach (<anonymous>)
13 verbose stack     at /usr/lib/node_modules/npm/node_modules/lock-verify/index.js:25:25
14 verbose cwd /opt/zigbee2mqtt
15 verbose Linux 5.10.63-v7+
16 verbose argv "/usr/bin/node" "/usr/bin/npm" "ci"
17 verbose node v12.22.12
18 verbose npm  v6.14.16
19 error Cannot read property 'ajv' of undefined
20 verbose exit [ 1, true ]0 info it worked if it ends with ok
Dodane : 05/01/2024 11:45 am
