Shelly MQTT domotic...
Shelly MQTT domoticz mi sie przywiesza
23 Wpisów
4,835 Wyświetleń
gregaicha
(@gregaicha)
Wpisów: 64
SUPER :)))
Na nowy obrazie nie ma problemu 🙂
Problem rozwiązany
Dodane : 18/02/2019 3:21 am
gregaicha
(@gregaicha)
Wpisów: 64
Świeżo po testach :)))
2 bledy sie pojawiły
2019-02-17 14:43:35.781 Error: (Monitoring RBPi) 'onStart' failed 'KeyError'.
2019-02-17 14:43:35.781 Error: (Monitoring RBPi) ----> Line 235 in /home/pi/domoticz/plugins/PiMonitor-Plugin/plugin.py, function onStart
2019-02-17 14:43:35.781 Error: (Monitoring RBPi) ----> Line 84 in /home/pi/domoticz/plugins/PiMonitor-Plugin/plugin.py, function onStart
2019-02-17 14:43:36.180 Status: MQTT: Connecting to localhost:1883
2019-02-17 14:43:32.563 Sunrise: 06:48:00 SunSet: 16:52:00
2019-02-17 14:43:32.563 Day length: 10:04:00 Sun at south: 11:05:00
2019-02-17 14:43:32.563 Civil twilight start: 06:13:00 Civil twilight end: 17:27:00
2019-02-17 14:43:32.563 Nautical twilight start: 05:33:00 Nautical twilight end: 18:07:00
2019-02-17 14:43:32.563 Astronomical twilight start: 04:54:00 Astronomical twilight end: 18:46:00
2019-02-17 14:43:32.182 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2019-02-17 14:43:32.192 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
2019-02-17 14:43:32.203 Status: Startup Path: /home/pi/domoticz/
2019-02-17 14:43:32.563 Status: EventSystem: reset all events...
2019-02-17 14:43:33.116 Active notification Subsystems: (0/13)
2019-02-17 14:43:33.176 Starting shared server on: :::6144
2019-02-17 14:43:33.050 Status: PluginSystem: Started, Python version '3.5.3'.
2019-02-17 14:43:33.156 Status: WebServer(HTTP) started on address: :: with port 8084
2019-02-17 14:43:33.171 Status: WebServer(SSL) started on address: :: with port 443
2019-02-17 14:43:33.173 Status: Proxymanager started.
2019-02-17 14:43:33.174 Status: Camera: settings (re)loaded
2019-02-17 14:43:33.176 Status: TCPServer: shared server started...
2019-02-17 14:43:33.176 Status: RxQueue: queue worker started...
2019-02-17 14:43:35.771 (Monitoring RBPi) Debug logging mask set to: NONE
2019-02-17 14:43:35.177 Status: (Monitoring RBPi) Started.
2019-02-17 14:43:35.178 Status: EventSystem: reset all events...
2019-02-17 14:43:35.178 Status: EventSystem: reset all device statuses...
2019-02-17 14:43:35.338 Status: Python EventSystem: Initalizing event module.
2019-02-17 14:43:35.338 Status: EventSystem: Started
2019-02-17 14:43:35.338 Status: EventSystem: Queue thread started...
2019-02-17 14:43:35.614 Status: PluginSystem: Entering work loop.
2019-02-17 14:43:35.764 Status: (Monitoring RBPi) Entering work loop.
2019-02-17 14:43:35.764 Status: (Monitoring RBPi) Initialized version 2.1.0, author 'Xorfor'
2019-02-17 14:43:36.281 Status: MQTT: connected to: localhost:1883
2019-02-17 14:43:36.382 Status: MQTT: Subscribed
2019-02-18 02:13:48.651 Sunrise: 06:46:00 SunSet: 16:54:00
2019-02-18 02:13:48.651 Day length: 10:08:00 Sun at south: 11:05:00
2019-02-18 02:13:48.651 Civil twilight start: 06:11:00 Civil twilight end: 17:29:00
2019-02-18 02:13:48.651 Nautical twilight start: 05:31:00 Nautical twilight end: 18:08:00
2019-02-18 02:13:48.652 Astronomical twilight start: 04:52:00 Astronomical twilight end: 18:48:00
2019-02-18 02:13:48.652 Status: EventSystem: reset all events...
2019-02-18 02:13:58.687 Status: Incoming connection from: 10.1.9.26
2019-02-18 02:15:07.538 Status: (shelly) Started.
2019-02-18 02:15:07.827 Status: (shelly) Entering work loop.
2019-02-18 02:15:07.827 Status: (shelly) Initialized version 0.3.1
2019-02-18 02:18:05.012 Status: User: Admin initiated a switch command (38/shelly - shelly1-554309-0/Off)
2019-02-18 02:18:06.723 Status: User: Admin initiated a switch command (38/shelly - shelly1-554309-0/On)
2019-02-18 02:18:08.289 Status: User: Admin initiated a switch command (38/shelly - shelly1-554309-0/Off)
2019-02-18 02:18:12.245 Status: User: Admin initiated a switch command (38/shelly - shelly1-554309-0/On)
2019-02-18 02:18:38.772 Status: User: Admin initiated a switch command (38/shelly - shelly1-554309-0/Off)
2019-02-18 02:18:40.846 Status: User: Admin initiated a switch command (38/shelly - shelly1-554309-0/On)
Dodane : 18/02/2019 3:23 am
Te błędy wynikają z tego że PiMonitor startuje szybciej niż uruchomi się do końca domoticz i występują tylko przy starcie systemu
Dodane : 18/02/2019 9:41 am
Strona 2 / 2
