103 Wpisów
6 Użytkownicy
7 Reactions
9,338 Wyświetleń
Wpisów: 489
2020-06-08 22:20:01.868 Status: dzVents: Info: rain_rate: 0
2020-06-08 22:20:01.868 Status: dzVents: Info: total_rain: 19.200000762939
2020-06-08 22:20:01.868 Status: dzVents: Info: ------ Finished Script #1
2020-06-08 22:20:06.703 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":79,"nvalue":0,"svalue":"0.00;19.24"}
2020-06-08 22:20:06.834 Status: dzVents: Info: Handling events for: "STACJA_POGODY d", value: "0.00;19.24"
2020-06-08 22:20:06.835 Status: dzVents: Info: ------ Start internal script: Script #1: Device: "STACJA_POGODY d (dumy)", Index: 79
2020-06-08 22:20:06.835 Status: dzVents: Info: Device STACJA_POGODY d was changed
2020-06-08 22:20:06.835 Status: dzVents: Info: rain_rate: 0
2020-06-08 22:20:06.835 Status: dzVents: Info: total_rain: 19.200000762939
2020-06-08 22:20:06.835 Status: dzVents: Info: ------ Finished Script #1
2020-06-08 22:20:11.712 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":79,"nvalue":0,"svalue":"0.00;19.24"}
2020-06-08 22:20:11.897 Status: dzVents: Info: Handling events for: "STACJA_POGODY d", value: "0.00;19.24"
2020-06-08 22:20:11.897 Status: dzVents: Info: ------ Start internal script: Script #1: Device: "STACJA_POGODY d (dumy)", Index: 79
2020-06-08 22:20:11.897 Status: dzVents: Info: Device STACJA_POGODY d was changed
2020-06-08 22:20:11.897 Status: dzVents: Info: rain_rate: 0
2020-06-08 22:20:11.897 Status: dzVents: Info: total_rain: 19.200000762939
2020-06-08 22:20:11.897 Status: dzVents: Info: ------ Finished Script #1
2020-06-08 22:20:16.762 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":79,"nvalue":0,"svalue":"0.00;19.24"}
2020-06-08 22:20:16.920 Status: dzVents: Info: Handling events for: "STACJA_POGODY d", value: "0.00;19.24"
2020-06-08 22:20:16.920 Status: dzVents: Info: ------ Start internal script: Script #1: Device: "STACJA_POGODY d (dumy)", Index: 79
2020-06-08 22:20:16.920 Status: dzVents: Info: Device STACJA_POGODY d was changed
2020-06-08 22:20:16.920 Status: dzVents: Info: rain_rate: 0
2020-06-08 22:20:16.920 Status: dzVents: Info: total_rain: 19.200000762939
2020-06-08 22:20:16.920 Status: dzVents: Info: ------ Finished Script #1
2020-06-08 22:20:21.743 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":79,"nvalue":0,"svalue":"0.00;19.24"}
2020-06-08 22:20:21.898 Status: dzVents: Info: Handling events for: "STACJA_POGODY d", value: "0.00;19.24"
2020-06-08 22:20:21.898 Status: dzVents: Info: ------ Start internal script: Script #1: Device: "STACJA_POGODY d (dumy)", Index: 79
2020-06-08 22:20:21.898 Status: dzVents: Info: Device STACJA_POGODY d was changed
2020-06-08 22:20:21.898 Status: dzVents: Info: rain_rate: 0
2020-06-08 22:20:21.899 Status: dzVents: Info: total_rain: 19.200000762939
2020-06-08 22:20:21.899 Status: dzVents: Info: ------ Finished Script #1
2020-06-08 22:20:26.760 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":79,"nvalue":0,"svalue":"0.00;19.24"}
2020-06-08 22:20:31.765 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":79,"nvalue":0,"svalue":"0.00;19.24"}
2020-06-08 22:20:36.769 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":79,"nvalue":0,"svalue":"0.00;19.24"}
2020-06-08 22:20:41.775 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":79,"nvalue":0,"svalue":"0.00;19.24"}
2020-06-08 22:20:41.962 Status: dzVents: Info: Handling events for: "STACJA_POGODY d", value: "0.00;19.24"
2020-06-08 22:20:41.962 Status: dzVents: Info: ------ Start internal script: Script #1: Device: "STACJA_POGODY d (dumy)", Index: 79
2020-06-08 22:20:41.962 Status: dzVents: Info: Device STACJA_POGODY d was changed
2020-06-08 22:20:41.962 Status: dzVents: Info: rain_rate: 0
2020-06-08 22:20:41.962 Status: dzVents: Info: total_rain: 19.200000762939
2020-06-08 22:20:41.962 Status: dzVents: Info: ------ Finished Script #1
2020-06-08 22:20:46.790 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":79,"nvalue":0,"svalue":"0.00;19.24"}
2020-06-08 22:20:46.969 Status: dzVents: Info: Handling events for: "STACJA_POGODY d", value: "0.00;19.24"
2020-06-08 22:20:46.969 Status: dzVents: Info: ------ Start internal script: Script #1: Device: "STACJA_POGODY d (dumy)", Index: 79
2020-06-08 22:20:46.970 Status: dzVents: Info: Device STACJA_POGODY d was changed
2020-06-08 22:20:46.970 Status: dzVents: Info: rain_rate: 0
2020-06-08 22:20:46.970 Status: dzVents: Info: total_rain: 19.200000762939
2020-06-08 22:20:46.970 Status: dzVents: Info: ------ Finished Script #1
2020-06-08 22:20:51.532 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":81,"nvalue":0,"svalue":"0;N;0.08;0;?;?"}
@krzysztofch podłączyłem do zasilania po całej nocy i dzisiejszym dniu  ESP z T-6 v7 i wszystko działa normalnie
 3
9 Odpowiedzi
Wpisów: 489
@isom co proponujecie ustawienia poczatkowe ,nowa kafelka czy poczekac po 24 i zobaczyc
@krzysztofch proponuje nowy kafelek i ustawienia początkowe. Ja zaraz sobie zainstaluje wersję domoticzową i będę również obserwował. Teraz mam wersje nie-domoticz i "u mnie działa"
Wpisów: 489
@adrian  wszystko zrobilem od nowa ,narazie dziala.
Adrian a moglbys przyblizyc wyjasnic jak Afe deszcz  dziala , czyli jak rozwiazales ze sie to resetuje o 24?
Pytam zeby lepiej zrozumiec dzialanie tego sensora
@krzysztofch cześć, nic sie nie resetuje. cały czas rośnie. Tak napisał @isom, żeby zrobić.
Wpisów: 489
@adrian czyli Afe czaly czas dodaje i zapisuje to w swojej pamieci i tak w nieskonczonosc ?
Wpisów: 489
@adrian czyli wazne tu jest aby byl nowy kafelek od poczatku i dane zaczynaly sie od zera.
Nie wolno nic wysylac do niego i zmieniac kafelek ,tak musi trwac caly czas?
gdyby sie cos stalo to znow musze wykonac wszystko od nowa i trace historie w wykresach?
A rate pokazyje tylko z ostatniej godziny?
@krzysztofch rate pokazuje aktualna godzina-59minut, planuje zrobić w AFE jeszcze ustawienie wartości początkowych dla tych rate, rate_counter, żeby nie liczyć od zera lub kasować kafelka
Wpisów: 489
@adrian rownolegle od kilku dni wysylalem deszcz do innego kafelka za kazdym razem podwyzszajac o jeden counter i zgadza sie to.
o 24 zawsze sie kasowalo na zera i dodajac dalej liczylo dzien od nowa .Czyli sie to pokrywa z moimi probami
@krzysztofch napiszę tak " U mnie Działa " a  nie jestem informatykiem , a tak serio to napisałem wcześniej co trzeba zrobić
Wpisów: 489
Rano sie obudzilem i przed praca mialem w deszczu drugi dzien rate =nan ,pozatym wachlowalem tym sensorem ani rate ani counter sie nie zmienial.Nie bedac pewny czy to gpio od deszczu dziala ,po pracy,utworzylem przycisk z tym samym gpio co od deszcu i przycisk zmienial stan.Czyli gpio dziala Zreszta po pracy kafelek od deszcu byl na czerwono czyli od dluzszego czasu zaden sygnal do niego nie dochodzil od rana,pomimo wachlowania sensorem. .Nie wiem dlaczego.Utworzylem tez nowy kafelek i tez do niego nie dochodzil sygnal.
Teraz po pracy przeszedlem na wer6 i po http wszystko zadzialalo.Pomijajac ze niektore dane nie zostaly zapamietane i musialem dopisywac  a niektore byly zapamietane
Przechodze na mqtt.Wszystko dziala.Pokazuje mi rate i counter co nie chcialo pokazywac w wer7 .Nie robilem przy przejsciu ustawien poczatkowych.Odlanczajaz zasilanie tak jak wczesniej wyzerowaly sie rate i counter.
Moge znow przejsc na wer 7 ale czekam na Adrian na ciebie
Na jednym gpio mam skonfigurowane deszcz i przycisk bistabilny.Ten przycisk bistabilny wysyla mi do domoticza jako wlacznik impuls.Potem z tego przycisku w blokly mam ten swoj stary program ktory wysyla json do drugiego kafelka dane deszczu.Dzialaja na raz deszcz afe i z przycisku.
2 Odpowiedzi
@krzysztofch hey, nie rób na jednym gpio dwóch elementów deszcz i przycisk - AFE będzie zachowywało się w niekontrolowany sposób. Ja wczoraj zainstalowałem AFE z Domoticz i tak mi rysuje wykres opadów, wszystko przychodzi elegancko
deszczyk
Wpisów: 489
@adrian Na wer 6 dziala mi normalnie  dwie rzeczy na jednym gpio ale to krotkie testy ,chcialem z ciekawosci zobaczyc jak sie to bedzie zachowywalo i czy nie bedzie sie grzyzlo .Ok wracam na wer 7 i ustawie jedno gpio ,jak bedzie dzialac to kiedys sobie porobie proby z tym gpio na dwie inne rzeczy
Wpisów: 489
ok przeszedlem na wer7 od razy counter na nowym kafelku wskoczyl na dwa.Nie robilem ustawien poczatkowych.
POwachlowalem kilka razy czujnikiem wskoczylo na 7.2 potem znow pare razy wskoczylo na 9,3.
Teraz znow sprawdzam wskoczylo na 2.
Rate caly czas 0 odswierzanie ustawione co 6 min
Strona 11 / 13
