ArduinoHA, Multi St...
ArduinoHA, Multi State Button nie wyzwala automatyzacji
1 Wpisów
1 Użytkownicy
1,945 Wyświetleń
(@dawidkadziela)
Wpisów: 32
[#2641]
Cześć Wszystkim!
Arduino widzi się z HA. HA widzi opcje button short press i button long press, ale nie reaguje przy zwarciu pinu 9 do GND. Poniżej załączam szkic z Arduino i szkic automatyzacji.
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
alias: Mybutton ON to OFF
description: hej
trigger:
  - platform: device
    domain: mqtt
    device_id: 0ed8d7a687af41ade0c126a651e8485d
    type: button_short_press
    subtype: mybtn
    discovery_id: 0010fa6e384a mybtn_button_short_press
condition:
  - condition: and
    conditions:
      - condition: state
        entity_id: switch.relay_1_102
        state: 'on'
action:
  - service: switch.turn_off
    target:
mode: single
#include <Ethernet.h>
#include <ArduinoHA.h>
#define MY_DEBUG
// This example uses JC Button library
//  https://github.com/JChristensen/JC_Button
#include <JC_Button.h>
#define BUTTON_PIN      9
#define BUTTON_NAME     "mybtn"
#define BROKER_ADDR     IPAddress(192,168,0,140)
#define BROKER_USERNAME     "mqtt" // replace with your credentials
#define BROKER_PASSWORD     "1234"
byte mac[] = {0x00, 0x10, 0xFA, 0x6E, 0x38, 0x4A};
EthernetClient client;
HADevice device(mac, sizeof(mac));
HAMqtt mqtt(client, device);
HATriggers triggers;
Button btn(BUTTON_PIN);
bool holdingBtn = false;
void setup() {
  Serial.begin(9600);
    // you don't need to verify return status
    Ethernet.begin(mac);
    // set device's details (optional)
    device.setName("Arduino");
    device.setSoftwareVersion("1.0.0");
    // setup triggers
    triggers.add("button_short_press", BUTTON_NAME);
    triggers.add("button_long_press", BUTTON_NAME);
    btn.begin();
    mqtt.begin(BROKER_ADDR);
void loop() {
    Ethernet.maintain();
    mqtt.loop();
    btn.read();
    if (btn.pressedFor(3000) && !holdingBtn) {
        triggers.trigger("button_long_press", BUTTON_NAME);
        holdingBtn = true;
    } else if (btn.wasReleased()) {
        if (holdingBtn) {
            holdingBtn = false;
        } else {
            triggers.trigger("button_short_press", BUTTON_NAME);
Dodane : 03/12/2021 4:51 pm
