ESPHome + pipsolar,...
Home Assistant ESP32 ESPHome + pipsolar, błąd odczytu QPIGS
1,506 Wyświetleń
(@szpila86)
Wpisów: 367
[#5968]
Hej
potrzebuję pomocy przy w zasadzie gotowym projekcie z github ( https://github.com/syssi/esphome-pipsolar)
wszystko śmiga tylko problem z parsowaniem odpowiedzi na QPIGS
Sending polling command : QPIGS with length 5
17:59:04	[D]	[uart_debug:114]
>>> 51:50:49:47:53:B7:A9:0D
17:59:05	[D]	[uart_debug:114]
<<< 28:32:31:37:2E:31:20:35:30:2E:30:20:32:31:37:2E:31:20:35:30:2E:30:20:30:31:39:35:20:30:31:38:31:20:30:30:33:20:32:39:39:20:30:30:2E:34:30:20:30:30:30:20:30:30:30:20:30:30:32:30:20:30:30:2E:30:20:30:30:30:2E:30:20:30:30:2E:30:30:20:30:30:30:30:30:20:30:30:30:31:30:30:30:30:20:30:30:20:30:30:20:30:30:30:30:30:20:30:31:30:20:30:20:30:31:20:30:30:30:30:44:E3:0D
17:59:05	[VV	][scheduler:226]
Running interval 'update' with interval=1000 last_execution=5664057 (now=5665057)
17:59:06	[VV	][scheduler:226]
Running interval 'update' with interval=1000 last_execution=5665057 (now=5666061)
17:59:07	[VV	][scheduler:226]
Running interval 'update' with interval=1000 last_execution=5666057 (now=5667057)
17:59:08	[VV	][scheduler:226]
Running interval 'update' with interval=1000 last_execution=5667057 (now=5668062)
17:59:09	[VV	][scheduler:226]
Running interval '' with interval=10000 last_execution=5658901 (now=5668901)
Running interval 'update' with interval=1000 last_execution=5668057 (now=5669057)
17:59:09	[D]	[pipsolar:759]
timeout command to poll: QPIGS
17:59:09	[D]	[pipsolar:842]
przekroczony czas raczej wynika z przekroczeniem czasu biblioteki pipsolar a nie odczytem z portu który wygląda poprawnie.
Analiza QPIGS
(217.1 50.0 217.1 50.0 0195 0181 003 299 00.40 000 000 0020 00.0 000.0 00.00 00000 01 0 01 0000D)
Podział na pola (przykład):
  1. Grid voltage: 217.1
  2. Grid frequency: 50.0
  3. AC output voltage: 217.1
  4. AC output frequency: 50.0
  5. AC output apparent power: 0195
  6. AC output active power: 0181
  7. Output load percent: 003
  8. Bus voltage: 299
  9. Battery voltage: 00.40
  10. Battery charging current: 000
  11. Battery capacity: 000
  12. Inverter heat sink temperature: 0020
  13. PV input current: 00.0
  14. PV input voltage: 000.0
  15. SCC battery voltage: 00.00
  16. Battery discharge current: 00000
  17. Flags (b7b6b5b4b3b2b1b0): 01 0 01
  18. Extra: 0000D
Miał ktoś podobny problem? O co to może chodzić?
Dodane : 04/12/2024 9:04 pm
(@szpila86)
Wpisów: 367
Prawdopodobnie problem w tym że dane są rozdzielone są spacją nie przecinkiem. Ale nie wiem jak to sprawdzić ;(
Dodane : 06/12/2024 6:47 pm
(@szpila86)
Wpisów: 367
Poddaje się
prawdopodobnie popełniłem głupotę ale nie wiem gdzie wiec znalazłem wyjście na ten moment
# KONFIGURACJA OGÓLNA
substitutions:
  tx_pin: GPIO16
  rx_pin: GPIO17
esphome:
  platform: ESP32
  board: esp32dev
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
  manual_ip:
    static_ip: 192.168.86.78
    gateway: 192.168.86.1
    subnet: 255.255.255.0
    dns1: 8.8.8.8
    dns2: 8.8.4.4
logger:
  level: DEBUG
api:
  encryption:
    key: !secret key
ota:
  password: !secret ota_password
  platform: esphome
web_server:
  port: 80
# KONFIGURACJA UART
uart:
  baud_rate: 2400
  tx_pin: GPIO16
  rx_pin: GPIO17
  debug:
    direction: BOTH
    after:
      delimiter: "\r"  # Koniec wiadomości
# Wysyłanie poleceń QPIGS
interval:
  - interval: 10s
    then:
      - logger.log:
          level: INFO
          format: "Wysyłanie QPIGS..."
      - uart.write: [0x51, 0x50, 0x49, 0x47, 0x53, 0xB7, 0xA9, 0x0D]
      - delay: 3s
      - script.execute: parse_qpigs
# Wysyłanie poleceń QPIRI
  - interval: 11s
    then:
      - logger.log:
          level: INFO
          format: "Wysyłanie QPIRI..."
      - uart.write: [0x51, 0x50, 0x49, 0x52, 0x49, 0xD7, 0xA9, 0x0D]
      - delay: 3s
      - script.execute: parse_qpiri
# Wysyłanie poleceń QFLAG
  - interval: 12s
    then:
      - logger.log:
          level: INFO
          format: "Wysyłanie polecenia UART QFLAG..."
      - uart.write: [0x51, 0x46, 0x4C, 0x41, 0x47, 0xA9, 0x0D]  # Polecenie QFLAG
      - delay: 2s
      - script.execute: parse_qflag  # Uruchom skrypt przetwarzający dane QFLAG
# QMOD
  - interval: 15s
    then:
      - logger.log:
          level: INFO
          format: "Wysyłanie polecenia UART QMOD..."
      - uart.write: [0x51, 0x4D, 0x4F, 0x44, 0x49, 0x0D]  # Polecenie QMOD
      - delay: 2s
      - script.execute: parse_qmod  # Uruchom skrypt przetwarzający dane QMOD
# SKRYPTY DO PARSOWANIA
# Skrypt przetwarzający dane QPIGS
script:
  - id: parse_qpigs
    then:
      - lambda: |-
          static std::string buffer;
          uint8_t byte;
          while (id(uart_0).read_byte(&byte)) {
            char c = static_cast<char>(byte);
            buffer += c;
            if (c == '\r') {
              ESP_LOGI("UART", "Odebrano QPIGS: %s", buffer.c_str());
              if (buffer[0] == '(' && buffer.length() > 70) {
                id(grid_voltage).publish_state(atof(buffer.substr(1, 5).c_str()));
                id(grid_frequency).publish_state(atof(buffer.substr(7, 4).c_str()));
                id(output_voltage).publish_state(atof(buffer.substr(12, 5).c_str()));
                id(output_frequency).publish_state(atof(buffer.substr(18, 4).c_str()));
                id(output_power).publish_state(atof(buffer.substr(20, 4).c_str()));
                id(load_percent).publish_state(atof(buffer.substr(25, 4).c_str()));
                id(battery_voltage_qpigs).publish_state(atof(buffer.substr(39, 5).c_str()));
                id(charge_current).publish_state(atof(buffer.substr(30, 3).c_str()));
                id(discharge_current).publish_state(atof(buffer.substr(34, 4).c_str()));
                id(system_status).publish_state(atoi(buffer.substr(68, 2).c_str()));
                id(pv_voltage).publish_state(atof(buffer.substr(58, 4).c_str()));
                id(pv_power).publish_state(atof(buffer.substr(63, 4).c_str()));
              buffer.clear();
              break;
# Skrypt przetwarzający dane QPIRI
  - id: parse_qpiri
    then:
      - lambda: |-
          uint8_t byte;
            buffer += c;
            if (c == '\r') {
              ESP_LOGI("UART", "Odebrano QPIRI: %s", buffer.c_str());
              if (buffer[0] == '(' && buffer.length() > 100) {
                id(ac_output_voltage).publish_state(atof(buffer.substr(1, 5).c_str()));
                id(battery_voltage_qpiri).publish_state(atof(buffer.substr(7, 5).c_str()));
                id(ac_input_voltage).publish_state(atof(buffer.substr(13, 5).c_str()));
                id(ac_output_frequency).publish_state(atof(buffer.substr(19, 4).c_str()));
                id(battery_charging_voltage).publish_state(atof(buffer.substr(24, 5).c_str()));
                id(ac_output_max_apparent_power).publish_state(atof(buffer.substr(30, 5).c_str()));
                id(ac_output_max_active_power).publish_state(atof(buffer.substr(36, 5).c_str()));
                id(battery_max_voltage).publish_state(atof(buffer.substr(42, 5).c_str()));
                id(battery_min_voltage).publish_state(atof(buffer.substr(48, 5).c_str()));
                id(battery_cutoff_voltage).publish_state(atof(buffer.substr(54, 5).c_str()));
                id(battery_recovery_voltage).publish_state(atof(buffer.substr(60, 5).c_str()));
                id(battery_float_charge_voltage).publish_state(atof(buffer.substr(66, 5).c_str()));
                id(battery_number).publish_state(atoi(buffer.substr(72, 2).c_str()));
                id(max_battery_charging_current).publish_state(atof(buffer.substr(75, 3).c_str()));
                id(inverter_temperature).publish_state(atof(buffer.substr(92, 4).c_str()));
                id(fan_mode).publish_state(atoi(buffer.substr(97, 1).c_str()));
                id(end_code).publish_state(atoi(buffer.substr(101, 3).c_str()));
              buffer.clear();
              break;
#  QFLAG
  - id: parse_qflag
    then:
      - lambda: |-
          uint8_t byte;
            buffer += c;
            if (c == '\r') {
              ESP_LOGI("UART", "Odebrano QFLAG: %s", buffer.c_str());
              if (buffer[0] == '(' && buffer.length() > 15) {
                id(grid_bypass_flag).publish_state(atoi(buffer.substr(1, 1).c_str()));  // Flaga bypassu sieci
                id(output_short_circuit_flag).publish_state(atoi(buffer.substr(2, 1).c_str()));  // Flaga zwarcia wyjścia
                id(power_saving_mode_flag).publish_state(atoi(buffer.substr(3, 1).c_str()));  // Flaga trybu oszczędzania energii
                id(battery_weak_flag).publish_state(atoi(buffer.substr(4, 1).c_str()));  // Flaga słabej baterii
                id(load_on_flag).publish_state(atoi(buffer.substr(5, 1).c_str()));  // Flaga włączenia obciążenia
                id(battery_overcharge_flag).publish_state(atoi(buffer.substr(6, 1).c_str()));  // Flaga przeładowania baterii
                id(system_overheat_flag).publish_state(atoi(buffer.substr(7, 1).c_str()));  // Flaga przegrzania systemu
                id(system_shutdown_flag).publish_state(atoi(buffer.substr(8, 1).c_str()));  // Flaga wyłączenia systemu
                id(inverter_fault_flag).publish_state(atoi(buffer.substr(9, 1).c_str()));  // Flaga awarii falownika
                id(charger_fault_flag).publish_state(atoi(buffer.substr(10, 1).c_str()));  // Flaga awarii ładowarki
                id(pv_power_saving_flag).publish_state(atoi(buffer.substr(11, 1).c_str()));  // Flaga oszczędzania PV
                id(internal_com_error_flag).publish_state(atoi(buffer.substr(12, 1).c_str()));  // Flaga błędu komunikacji wewnętrznej
                id(emergency_shutdown_flag).publish_state(atoi(buffer.substr(13, 1).c_str()));  // Flaga awaryjnego wyłączenia
                id(low_frequency_flag).publish_state(atoi(buffer.substr(14, 1).c_str()));  // Flaga niskiej częstotliwości
              buffer.clear();
              break;
#  QMOD
  - id: parse_qmod
    then:
      - lambda: |-
          uint8_t byte;
            buffer += c;
            if (c == '\r') {
              ESP_LOGI("UART", "Odebrano QMOD: %s", buffer.c_str());
              // Sprawdź poprawność odpowiedzi
              if (buffer[0] == '(' && buffer.length() == 3) {  // Oczekiwany format QMOD: np. "(S)"
                char mode = buffer[1];  // Drugi znak to tryb pracy
                std::string mode_str;
                switch (mode) {
                  case 'S': mode_str = "Standby"; break;
                  case 'L': mode_str = "Line"; break;
                  case 'B': mode_str = "Battery"; break;
                  case 'F': mode_str = "Fault"; break;
                  case 'P': mode_str = "Power Saving"; break;
                  case 'H': mode_str = "Standby Heating"; break;
                  default: mode_str = "Unknown"; break;
                id(inverter_mode).publish_state(mode_str);
              } else {
                ESP_LOGW("QMOD", "Nieprawidłowa odpowiedź: %s", buffer.c_str());
                id(inverter_mode).publish_state("Invalid Data");
              buffer.clear();
              break;
# SENSORY
sensor:
  # Sensory dla QPIGS
  - platform: template
    name: "Napięcie Sieci (AC)"
    unit_of_measurement: "V"
    name: "Częstotliwość Sieci (AC)"
    unit_of_measurement: "Hz"
    name: "Napięcie Wyjściowe (AC)"
    name: "Częstotliwość Wyjściowa (AC)"
    name: "Moc Wyjściowa (W)"
    unit_of_measurement: "W"
    unit_of_measurement: "%"
    name: "Napięcie Baterii (QPIGS)"
    name: "Prąd Ładowania (A)"
    unit_of_measurement: "A"
    name: "Prąd Rozładowania (A)"
    name: "Napięcie PV (V)"
    name: "Moc PV (W)"
    unit_of_measurement: ""
  # Sensory QPIRI
    name: "Napięcie Wejściowe (AC)"
    name: "Napięcie Ładowania Baterii (V)"
    name: "Maksymalna Moc Wyjściowa (VA)"
    unit_of_measurement: "VA"
    name: "Maksymalna Moc Wyjściowa (W)"
    name: "Maksymalne Napięcie Akumulatora (V)"
    name: "Minimalne Napięcie Akumulatora (V)"
    name: "Napięcie Odcięcia Akumulatora (V)"
    name: "Napięcie Odzysku Zasilania (V)"
    name: "Napięcie Zakończenia Ładowania (V)"
    name: "Liczba Podłączonych Akumulatorów"
    name: "Maksymalny Prąd Ładowania Akumulatorów (A)"
    name: "Temperatura Falownika (°C)"
    unit_of_measurement: "°C"
    name: "Tryb Wentylatora"
binary_sensor:
  # Flagi QFLAG
    lambda: |-
      return id(grid_bypass_flag).state == 1;
    device_class: power
    lambda: |-
      return id(output_short_circuit_flag).state == 1;
    device_class: safety
    name: "Tryb Oszczędzania Energii"
    lambda: |-
      return id(power_saving_mode_flag).state == 1;
    device_class: power
    lambda: |-
      return id(battery_weak_flag).state == 1;
    device_class: battery
    name: "Obciążenie Włączone"
    lambda: |-
      return id(load_on_flag).state == 1;
    device_class: power
    lambda: |-
      return id(battery_overcharge_flag).state == 1;
    lambda: |-
      return id(system_overheat_flag).state == 1;
    device_class: problem
    lambda: |-
      return id(system_shutdown_flag).state == 1;
    name: "Awaria Falownika"
    lambda: |-
      return id(inverter_fault_flag).state == 1;
    name: "Awaria Ładowarki"
    lambda: |-
      return id(charger_fault_flag).state == 1;
    name: "Tryb Oszczędzania PV"
    lambda: |-
      return id(pv_power_saving_flag).state == 1;
    device_class: power
    name: "Błąd Komunikacji Wewnętrznej"
    lambda: |-
      return id(internal_com_error_flag).state == 1;
    name: "Awaryjne Wyłączenie"
    lambda: |-
      return id(emergency_shutdown_flag).state == 1;
    name: "Niska Częstotliwość"
    lambda: |-
      return id(low_frequency_flag).state == 1;
# TEKSTOWE SENSORY (QMOD)
text_sensor:
    name: "Tryb Pracy Falownika"
    icon: "mdi:transmission-tower"
QMOD jeszcze nie działa reszta z grubsza poprawnie
Chętni sobie doszlifują.....lub nie 😉
Dodane : 07/12/2024 10:24 am
(@rychmar)
Udało się komuś odczytać dane z falownika te które są na bieżąco modyfikowane np. obciążenie, napięcie na panelach, moc paneli ?
Mam takie błędy. Falownik Qoltec Off Grid 6kw.
Plik wgrywałem powyższy i ten oryginalny pipsolar i cały czas większe lub mniejsze błędy ale nigdy nie podał powyższych danych.
[14:08:14][D][pipsolar:776]: checking crc on incoming message
[14:08:14][D][pipsolar:785]: CRC NOK expected: E1 9F but got: EE 9B
[14:08:14][D][pipsolar:840]: Sending polling command : QMOD with length 4
[14:08:15][D][pipsolar:776]: checking crc on incoming message
[14:08:15][D][pipsolar:779]: CRC OK
Dodane : 22/03/2025 3:13 pm
