Pierwsza własna int...
Home Assistant Pierwsza własna integracja
638 Wyświetleń
(@szpila86)
Wpisów: 367
Hej
jest gdzieś opisane tworzenie integracji dla opornych ? ;D
Próbuję coś zdziałać z integracją it4wifi na podstawie integracji dla OH
import logging
import requests
from homeassistant.components.switch import SwitchEntity
from homeassistant.const import CONF_NAME
_LOGGER = logging.getLogger(__name__)
def setup_platform(hass, config, add_entities, discovery_info=None):
    """Set up the IT4Wifi switch platform."""
    name = config.get(CONF_NAME)
    add_entities([It4WifiSwitch(name)])
class It4WifiSwitch(SwitchEntity):
    """Representation of an IT4Wifi switch."""
    def __init__(self, name):
        """Initialize the IT4Wifi switch."""
        self._name = name
        self._state = False
    @property
    def name(self):
        """Return the name of the switch."""
        return self._name
    @property
    def is_on(self):
        """Return true if the switch is on."""
        return self._state
    def turn_on(self, **kwargs):
        """Turn the switch on."""
        self._state = True
        self._send_command('open')
    def turn_off(self, **kwargs):
        """Turn the switch off."""
        self._state = False
        self._send_command('close')
    def _send_command(self, command):
        """Send a command to the IT4Wifi module."""
        url = f"http://<IP_ADDRESS>/send_command?cmd={command}"
        response = requests.get(url)
        if response.status_code == 200:
            _LOGGER.info(f"Successfully sent command: {command}")
        else:
            _LOGGER.error(f"Failed to send command: {command}")
import logging
from homeassistant.helpers import discovery
DOMAIN = 'it4wifi'
def setup(hass, config):
    """Set up the IT4Wifi component."""
    _LOGGER.info("Starting setup for IT4Wifi component")
    hass.states.set(f"{DOMAIN}.setup", "Starting")
    # Discover and load platforms
    for component in ['switch']:
        _LOGGER.info(f"Attempting to load platform: {component}")
        discovery.load_platform(hass, component, DOMAIN, {}, config)
    hass.states.set(f"{DOMAIN}.setup", "Completed")
    _LOGGER.info("Completed setup for IT4Wifi component")
    return True
  "domain": "it4wifi",
  "name": "IT4Wifi",
  "documentation": "https://example.com",
  "dependencies": [],
  "codeowners": ["@your_github_username"],
  "requirements": ["requests"]
Dodane : 02/06/2024 5:59 pm
(@szpila86)
Wpisów: 367
OK po wielu próbach napisania skryptu stanowiącego sam most i licznych próbach autoryzacji przez przypadek znalazłem tą integrację
https://github.com/PatrikTrestik/homeassistant_nicegate
Wrzucam w HA podaje dane, przechodzę dalej podaje kod z naklejki (setup code) i mam ciągle błąd "Unknown error occurred"
Ma możliwość ktoś sprawdzić?
Dodane : 11/06/2024 12:44 pm
(@konrad1)
Na Twoim miejscu sprawdziłbym logi. Wtedy można myśleć co nie działa.
Dodane : 25/06/2024 1:36 pm
(@szpila86)
Wpisów: 367
Problem z uwierzytelnianiem próbowałem zmienić na nowsze ale się zapetlilem i nie mogę tego przeskoczyć
Dodane : 25/06/2024 1:44 pm
