Błąd podczas instal...
Błąd podczas instalacji bindingu Sharp TV
1 Wpisów
1 Użytkownicy
1,356 Wyświetleń
(@edass)
Wpisów: 224
Czy ktoś podpowie co może powodować ten błąd i jak sobie z nim poradzić?
<pre>
2019-01-25 19:26:33.523 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.sharptv-2.5.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.sharptv [240]
Unresolved requirement: Import-Package: org.eclipse.jdt.annotation; resolution:="optional"
Unresolved requirement: Import-Package: org.eclipse.smarthome.config.discovery.upnp
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [10:org.apache.felix.fileinstall:3.6.4]
2019-01-25 19:26:33.782 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.sharptv-2.5.0-SNAPSHOT.jar
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [10:org.apache.felix.fileinstall:3.6.4]
</pre>
-----EDIT----
Trzeba się zalogować do karaf i wydać polecenie:
feature:install esh-io-transport-upnp
Dodane : 25/01/2019 8:34 pm
