OH2 + PLEX
1 Wpisów
1 Użytkownicy
2,161 Wyświetleń
(@tomaszraszowski)
Wpisów: 162
Specyfikacja mojego sprzętu w moim podpisie:
Problem jaki napotkałem to brak możliwości sterowania PMS za pomocą OH2, mimo iż mam podgląd statusów, czyli połączenie jako tako jest:
USTAWIENIA PO STONIE OH2
ITEMS
Switch PlexTVPower      "Power"         <video>     {plex="XXXXXXXXXXX#power"}
String PlexTVStatus     "Status [%s]"   <video>     {plex="XXXXXXXXXXX#state"}
String PlexTVTitle      "Title [%s]"    <video>     {plex="XXXXXXXXXXX#title"}
String PlexTVType       "Type [%s]"     <video>     {plex="XXXXXXXXXXX#type"}
String PlexTVCover      "Cover"         <video>     {plex="XXXXXXXXXXX#playback/cover"}
Dimmer PlexTVProgress   "Progress [%.1f%%]"    <video>    {plex="XXXXXXXXXXX#playback/progress"}
DateTime PlexTVEndTime  "End time [%1$tR]"     <video>    {plex="XXXXXXXXXXX#playback/endTime"}
Dimmer PlexTVVolume     "Volume"        <video>     {plex="XXXXXXXXXXX#playback/volume"}
Switch PlexTVPause      "Pause"         <video>     {plex="XXXXXXXXXXX#playback/pause"}
Switch PlexTVPlay       "Play"          <video>     {plex="XXXXXXXXXXX#playback/play"}
Switch PlexTVPlayPause  "PlayPause"     <video>     {plex="XXXXXXXXXXX#playback/playpause"}
Switch PlexTVStop       "Stop"          <video>     {plex="XXXXXXXXXXX#playback/stop"}
Switch PlexTVSelect     "Select"        <video>     {plex="XXXXXXXXXXX#navigation/select"}
Switch PlexTVBack       "Back"          <video>     {plex="XXXXXXXXXXX#navigation/back"}
Switch PlexTVUp         "Up"            <video>     {plex="XXXXXXXXXXX#navigation/moveUp"}
Switch PlexTVDown       "Down"          <video>     {plex="XXXXXXXXXXX#navigation/moveDown"}
Switch PlexTVLeft       "Left"          <video>     {plex="XXXXXXXXXXX#navigation/moveLeft"}
Switch PlexTVRight      "Right"         <video>     {plex="XXXXXXXXXXX#navigation/moveRight"}
Switch PlexTVForward    "Forward"       <video>     {plex="XXXXXXXXXXX#playback/stepForward"}
Switch PlexTVReverse    "Reverse"       <video>     {plex="XXXXXXXXXXX#playback/stepBack"}
SITEMAP
Frame {
        Switch item=PlexTVPower
        Text item=PlexTVStatus
        Slider item=PlexTVProgress visibility=[PlexTVStatus!="Stopped"]
        Setpoint item=PlexTVProgress visibility=[PlexTVStatus!="Stopped"] minValue=0 maxValue=100 step=1
        Text item=PlexTVEndTime visibility=[PlexTVStatus!="Stopped"]
        Text item=PlexTVTitle visibility=[PlexTVStatus!="Stopped"]
        Text item=PlexTVType visibility=[PlexTVStatus!="Stopped"]
        Switch item=PlexTVPause
        Switch item=PlexTVPlay
        Switch item=PlexTVPlayPause mappings=[ON="▐ ▌"]
        Switch item=PlexTVStop mappings=[ON="Stop"]
        Slider item=PlexTVVolume
        Switch item=PlexTVSelect mappings=[ON="Select"]
        Switch item=PlexTVBack mappings=[ON="Back"]
        Switch item=PlexTVUp mappings=[ON="⬆"]
        Switch item=PlexTVDown mappings=[ON="⬇"]
        Switch item=PlexTVLeft mappings=[ON="⬅"]
        Switch item=PlexTVRight mappings=[ON="➡"]
        Switch item=PlexTVForward mappings=[ON="⤏"]
        Switch item=PlexTVReverse mappings=[ON="⤎"]
Jeśli ktoś miał jakieśdoświadczenia z PLEX i OH2 może miał podobny problem ?
XXXXXXX = ID URZĄDZENIA -które zmieniłem celowo na potrzeby publikacji
To samo tyczy się tokena, który jest niepełny na te same potrzeby.
Dodane : 19/02/2017 7:51 pm
