[Tutorial] Openhab ...
[Tutorial] Openhab binding broadlink
27 Wpisów
10 Użytkownicy
4 Reactions
11.7 K Wyświetleń
(@maras)
Wpisów: 197
https://casa.profeta.in/f/0cd980aea5d748cf9505/?dl=1
Działająca wersja binding'u na OH 2.5
Dodane : 23/12/2019 1:48 pm
(@lukasz2)
Wpisów: 4
Cześć, czy komuś udało się spiąć OpenHab 3 z Broadlink RM4 Pro? Ja coś dziś kombinowałem ale bez powodzenia.
Dodane : 18/12/2021 2:03 am
(@mjeshurun)
Wpisów: 4
Dodane przez: @lukasz2
Yes, I'm using the RM4 Pro with OpenHAB 3.1.
Read this thread for details how to install and use the Broadlink binding:
https://community.openhab.org/t/broadlink-binding-for-rmx-a1-spx-and-mp-any-interest/22768/1503
Dodane : 18/12/2021 2:40 am
(@lukasz2)
Wpisów: 4
@mjeshurun
I've seen this thread before but there are 1472 messages in there ... no chance I'm reading all of this.
I read the first few messages and a link appears there:
https://github.com/davorf/BlackBeanControl
but from what i understand it's only for IR. I am more interested in RF.
What's the story about you? Do you speak polish? If so, why are you answering in English?
Dodane : 18/12/2021 6:23 pm
(@mjeshurun)
Wpisów: 4
@lukasz2
I don’t speak Polish (I used google translate).
I’m using the RM4 Pro with OpenHAB to control RF devices.
Dodane : 18/12/2021 6:27 pm
(@lukasz2)
Wpisów: 4
@mjeshurun
I have both BlackBeanControl and python-broadlink installed. I made the appropriate configuration in BlackBeanControl.ini:
[General]
IPAddress = 192.168.0.15
Port = 80
MACAddress = 12: DF: A5: FB: B2: 98
Timeout = 30
but I don't know what to do next. I tried to run the following but it crashes with some errors:
openhabian@openhabian:~/BlackBeanControl $ python BlackBeanControl.py -c test1
  File "BlackBeanControl.py", line 3, in <module>
    import broadlink, configparser
  File "/home/openhabian/.local/lib/python2.7/site-packages/broadlink/__init__.py", line 167
    dev_type: int,
SyntaxError: invalid syntax
openhabian@openhabian:~/BlackBeanControl $ python3 BlackBeanControl.py -c test1
  File "BlackBeanControl.py", line 197
    if (len(SentCommand) <> 8) or (not all(c in string.hexdigits for c in SentCommand)):
Any advice?
Dodane : 19/12/2021 1:50 am
(@mjeshurun)
Wpisów: 4
@lukasz2
To be honest, I configured my RM4 Pro almost 2 years ago, so I don't remember all the steps I took. I'm also not a developer, so I don't really understand the error messages you got.
I suggest you go over the following steps/questions and check you did everything:
1. since you are not going to use any IR codes, then remove BlackBeanControl from your system. No need to keep something problematic you are not going to use anyway.
2. did you copy the latest Broadlink binding jar file into OpenHAB's Addons folder? If I'm not mistaken, the latest binding version is 3.2.
3. did you learn your RF codes?
4. did you create a broadlink.map file including your RF codes and placed the file in OpenHAB's Transform folder?
5. did you add your broadlink device as a Thing in OpenHAB and configured it with your device's IP/MAC address and the Map file name?
6. did you create a Command Item for the broadlink device in OpenHAB?
Dodane : 19/12/2021 10:04 am
Strona 2 / 2
